ProNc and Intralink
Level 1
ProNc and Intralink
Does anyone who is using ProNc with Intralink know if there is a way to stop ncl files and tph files from being put into the current workspace. In pre Wildfire they would be put into the start directory.
Thanks!
Craig Broetzmann
Mold Design
3D Programming
Strattec Security Corporation
3333 W. Good Hope road
Milwaukee, WI 53209
(414)247-3497
cbroetzm@strattec.com
Re: ProNc and Intralink
You need M160 to fix that bug.......
Also, make sure you've defined in config.pro the path for pro_mf_cl_dir
"Craig Broetzmann" <cbroetzm@strattec.com> wrote in message news:49170@manuf...
Thanks!
Craig Broetzmann
Mold Design
3D Programming
Milwaukee, WI 53209
(414)247-3497
