Hi to all,
I have recently update my PTC product from Wildfire 5 to CREO 2. Until I have used Wildfire 5 I could import XML cabling file in Pro/E (from Zuken E3) with no problem. In Creo 2.0 when I try to import same file I receive an error about spools. In practice, CREO does not accept the separation character (ex. 0.5) of the spools. Infact if I modify manualy the XML file and change 0.5 in 0_5 the problem is solved.
So my questions are:
- how do I replace automatically "_" instead of "."?
- why in NWF file, the same spools with "0.5" is properly interpreted by CREO with no error?
Thanx
hello to all ,
I have the same problem with the spools , but when importing the XML in creo 3.0 .
does anyone have a solution how to replace "_" with "." , in the XML/spools ?
Thx
