RSD-to-Pro/Cable Compatibility Matrix
Highlighted
Visitor
Is anyone aware of a "Compatibility Matrix" which lists which versions of Pro/Cable can import .xml files from which versions of RSD?
For example, can an .xml file exported from RSD 8 be successfully imported into WF3's Pro/Cable?
More broadly, which RSD .xml files can any given version of WF accept? Can WF4 accept RSD 7 .xml's? Can WF3 accept RSD 9 .xml's?
I have been unable to locate such a Compatibility Matrix on PTC.com so I thought I'd poll the forum.
Thanks!
2 REPLIES 2
Highlighted
Re: RSD-to-Pro/Cable Compatibility Matrix
Hi Scott,
For sure RSD 6 and 7 are compatible with Wildfire 4.
I found this: http://www.ptc.com/WCMS/files/65524/en/DOC-L100-EN-360.pdf
RSD 8.0 and 9.0 are compatible with Wildfire 3.0 or later.
see this: http://www.ptc.com/WCMS/files/107484/en/DOC-L60290-EN-090.pdf
and this: http://www.ptc.com/WCMS/files/90502/en/DOC-60290-EN-080.pdf
Last time I used RSD it was version 6, and from what I remember there were an option (as a check box) to export xml in WF3 or pre-WF3.
I guess there is a similar option in RSD 8.
Hope this help!
Marc
Highlighted
Forest for the trees...
Yes, Marc-Andre, your links helped. You had a more thorough answer than you may have realized.
As I looked at the .pdf's in those links, I noticed that the material looked familiar. Well, those pages are from the installation guides contained on the installation CDs of RSD..., which I had already printed, bound, and read during my RSD installation. But somehow during installation, I breezed right over the "interoperability" info contained on those pages. That's what happens when one gets too focused on the task at hand (installing the software) and overlooks the larger picture.
That said, this assumes a person already has the software and can reference the installation guide on the CDs. But if a guy was interested in establishing a roadmap for future upgrades and wanted to determine compatibility between his various versions of his various software, a single online Compatiblity/Interoperability Matrix would still be a handy resource. Perhaps further hunting will turn up such a matrix on the PTC website, but if not hopefully PTC will create one (and make it easily found on the Support page by searching for "compatibility" or something equally intuitive).
Tip o' the hat to Marc-Andre for the links!
