Remove location not working
Regular Member
I am trying to remove a location in cabling but the following message appears on the bottom: "Splice location can not be removed". Is there some way to force to remove it?
Thanks!
Re: Remove location not working
Hi Edney,
It usually happens when location you are trying to remove has splice component referencing to it.
Make sure that there are no such components.
In case no component is referencing to this location, then you can force remove it by deleting portion between closet locations with "Delete Cable Portion"
