Ribbon cable modeling
Highlighted
Hello, everyone:
I am trying to model a coloured ribbon cable 24AWG (8 conductors), and my question is: can I modify the pitch between conductors? Right now i have .2 mm between conductors centerlines... but my connector has 2.54 mm pitch. So i would need my ribbon cable to be the same 2.54 mm pitch. Can I do this in CREO? I would appreciate your support.
Highlighted
Re: Ribbon cable modeling
Hope this helps
Article - CS66721
Ribbon cable width cannot be changed in Creo Parametric
Modified: 24-Aug-2020
Applies To
  • Creo Parametric 1.0 F000 to 7.0.1.0
Description
  • Ribbon cables with distance in between the cable conductors cannot be created such like
O-O-O-O-O-O     instead of     OOOOOO
  • Ribbon spool parameter WIDTH does not work
  • Ribbon cable width cannot be changed
Resolution
