Share quick access toolbar across all environments
dhermosillo
Currently in Creo Parametric, the quick access toolbar has to be customized for each environment, part, assembly, drawing, piping, cabling, flattened cable, etc.
One of the great things about the MS quick access toolbar is that it returns the use of human's inate spacial recognition ability, which the ribbon takes away.
By having the quick access toolbar change in every environment, PTC has eliminated that benefit altogether.  Also, it asks the user to set up 3 toolbars at minimum and 10+ toolbars depending on what modules are being used.
PTC, please allow the quick access toolbar customizations to be shared across all enviroments.
nmalik
(To:dhermosillo)
I agree that not only the Quick Access Toolbar should span across all Creo environments but also any custom tabs as well.
