Hi Gurus,
This model uses sheet metal to model a flex circuit... (when is PTC going to come out with a flex circuit modeling package or have they already?)
Please see the attached gif image for what the final model needs to look like - the 'tab' on the left should be bent such that its at the same interface as the tab on the right. I faked this one in using surfaces, however, what I really would like is to model it in such a way that I can flatten the tab on the left and have the system compute the correct flat pattern (i.e. length of the tab in the flat state).
Let me know if you have any ideas and thanks in advance,
Paul
