Just getting my feet wet with spec driven piping in WF 5.
When I use the button insert fitting I see no specification and sizes, and there are no previews.
When using the Free Fitting button, there are specifications and sizes, but proe does not assemble the fittings automatically in the pipes.
How can I make specifications and models (fittings) appear in the "Insert Fitting" menu?
thanks,
bern
Hi colfon
You must add daum cordinates and point. for fittinfg like valves,clamp,etc.
eg: coupling screen shot have been uploaded, just view it. then read help files regarding spec-driven.
Note:
see the z axis.
Thanks Viswanathan K,
that works great
bern
