To Create solid cable
Re: To Create solid cable
Folks,
I have routed a cable.  When displaying it in "centerline mode", the cable looks smooth and curvy.  When displaying in "thick cable mode", the cable looks clunky and segmented.  I have routed many cables and have not seen this before.  Is there a display setting that may have been manipulated or changed by our system admins that could be causing this?  Thank you.
Go to FILE - OPTIONS-MODEL DISPLAY
Check the options for SET SHADE QUALITY, maybe experiment with a higher number (warning, taking this to 10 and opening large assemblies will create serious performance issues)
Check LEVEL OF DETAIL, try turning off level of detial
Under ENTITY DISPLAY, you may want to experiment with the EDGE DISPLAY QUALITY, I'm not sure this one will help in your case.
