Is anyoneserving ProE (WF4) and Intralink 3.4 (M062) using VMWARE?
If so, are there any issues going to this model I should be aware of?
Paul
Hi Paul!
All our designers (more than 100) start up Pro/E Wf 4 and Pro/I 3.4 M070 from a virtualized Windows Server 2003.
We never had any problems.
Regards, Domenic
Is your FlexLM on the same virtualized server? if so, did you have to do something to ensure the NIC address never changes?
Paul
We run several FlexLM services on a VM. No issues with the NIC/MAC address. It remains constant.
Gerry
