What is the difference between Piping and Cabling? I want to perform wire harnessing tasks. Which would be more suitable? (I hope "wire harnessing" is not too generic)
Go to Creo Piping and Cabling Extension (PCX) | PTC for a summary document on Piping and Cabling - they are combined in the Creo PCX extension
Go to Creo Harness Manufacturing Extension (HMX) | PTC for a summary document on the Creo HMX electronic harness extension
That should get you the information you are looking for
Mike Brattoli
Thank you. Can you refer a manual that i can take a look at for cabling?
Shreyas,
Cabling is for working with wires, spools,electrical data,etc.
Piping is for working with pipes, linestocks, etc.
But also, take a look at the links that Mike suggested, above.
Amit
Thanks Amit. Do you know if there is a manual or so that i can download for cabling?
You can get additional information from the following:
Amit
ask Google for:
See
http://www.datajett.com/Cadd/ProE/Wildfire_Help/cabling.pdf
http://www.datajett.com/Cadd/ProE/Wildfire_Help/nonspecpiping.pdf
MH
