Why DWG and DXF file import always fail, whether is a linear about cad
there must be some entities in the autocad dwg or dxf file which can not be imported, I suggest please diagonosis, like deleting half of the entities in dwg, and try whether you can import or not. I guess the problem mostly lies with logos and hatches in autocad which may not be possible to import.
can you provide more details ? when it fail, does Creo schematics provide you error message ?
You can try the following :
Gaby.
