Wildfire 4.0 Installation
agaribay
3-Visitor
I downloaded 5 zipped folders for Wildfire 4.0 (Windows XP - 64bit) from
ptc.com. What do I need to do to start the installation process? In
other words, what do I do with these zipped folders (sorry I'm new to
the installation process). Do I need to unzip them and burn them as an
ISO image?
Any help would be appreciated.
Note: I am just testing the software, so it will be on a standalone
machine. I will not activate Intralink with this installation.
Thank you.
-Art
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
You can either unzip them all into 1 location and then run setup or you
can unzip them to differing locations and then run setup from the first
CD. I'd recommend that you read the getting started, readme first and
installation and configuration guides. These are all available on
www.ptc.com > Support > Reference documents.
Regards
Iain
Iain Lewis
Principal Application Specialist
iCentre UK
PTC
+44 (0) 7753 915635
