Hi team,
could you please answer
how to add new artifacts to central library.
Providing you have a central catalog directories set up, simply verify the catalog and then from the results, choose to submit all the items to the central catalog
Does that answer your question?
You are right but I donot have access to Central catalog.
currently I'm going thruh like submit temprary folder and those files admin ppl placing those files to central catalog. here every time generating new .dt files. instead of this can I make changes lively.
sorry i do not understand your question. I would suggest you speak with tech support and get them to walk you through the process
could you please tell me the support team contact number or email id. it will be great help.
