how to switch over to different templates in schematics?
msonnathi
Hi Team,
where Can I check which template used for that design and how to switch over the templates?
Madhu
1 ACCEPTED SOLUTION
The tool will only show you formats that the sheet content will fit in.
As an alternative create a new sheet with the template you want and use the move to sheet tool
To select a different drawing template/ format in the diagramming ribbon click "Change Sheet format" and selet your new drawing template
I checked that option, it shwoing only limited options. is any alternative?
