Adding fastener
Alexandrite
Adding fastener
How I can insert a fastener in this condition?
Maybe I could use the washer from 3D or there is an other way?
Thank you
 Federico
Tags (2)
Re: Adding fastener
Re: Adding fastener
If you are attempting to run a fastener analysis, look up the advanced fastener analysis help center, and it will give you a thorough explanation.  Fastener analysis can only be used through two components.
Re: Adding fastener
it's a universal solution with washer:
plate_washer.zip
