Creo Elements Direct-Adv Assembly
yhuang-2
9-Granite
I try to create a relation in my model. But I test it by the "position" function which has three function like "Stop at Clash" ,"Update Relations" ,"Physical"
"Update Relations" for test-relation. I use "Update Relations" it's ok ; nevertheless , "Physical" isn't ok. I use Physical to test my relation , but I don't know why my model can't move? Does Physical have any Constraint? I need somebody help me. Thank you very much.
Hello, it depends how you make constrains. I had that issues sometimes and manage to fix it by choosing the same accuracy in all parts and/or re-analize the constrains.
Hi.
under Physical in the 3D Coilot settings, you must set "Other parts" to free.
Also make sure the parts you want to move doesent touch.
Good Luck
Jens
