Creo flow analysis : Error:can't write results,underfined output file!
Amethyst
QQ图片20181219113822.pngHI,
I'm new here, this is a simple example,Detailed setup as blow, the mesh genrationQQ图片20181219124105.png the inflow boundary condition is 0.3m/sQQ图片20181219122950.png  and the outflow boundary condition isQQ图片20181219123414.pngand click Run icon, For a little while ,the soft pop up the dialogue box,QQ图片20181219124908.pngWhat am I supposed to do?  I'll uploap the files,Creo 4.0.Thanks in advance!
Tags (1)
7 REPLIES 7
Re: Creo flow analysis : Error:can't write results,underfined output file!
here is the operation video
I had to solve the same error yesterday. It was caused by NON-ASCII characters at the path to the working directory.
It seems, that Creo CFD module doesn’t support “Unicode” fully.
PZ
(probably this is not up to date reply, but it could be useful for someone else…)
YES,I have solve this problem BTW,Did YOU INSTALL CREO 6.0.1.0?
Yes, I've solved this issue just for 6.0.1.0...
will you  see knob "Wizard" Interface of Flow Analysis?in creo 6.0.1.0?or would you show me the picture that include "Wizard"
Unfortunately no, I’m convinced that 6.0.1.0 still has no Wizard dialog released.
(There is resource file for dialog at installation, but there is no gui access to call him from the Creo Flow Analysis dashboard.)
future
[ˈfyo͞oCHər]
名词未来; 将来; 前途; 前程
形容词未来的
