I have this situation:
-> plate
-> spacer
-> slide carriage
There the fasteners to link the 3 body
Between plate and spacer I used a interface "Contact"
(between spacer and slide carriage)
but the analisy don't run.
example 2
In the example, the fastener is a 3D model;
but if you use a fastener create in Simulate, how change the matter?
Thank you so much for your help
example 2
