How to Save a Static FEA Animation
SOLVED
Re: How to Save a Static FEA Animation
Oh I see, it is because I don't have windchill that this is the sequence for me.
Save a backup also has the same two options. The other options for animations, etc. are not shown.
I would contact PTC.  I think it is related to your windchill setup but I have never used windchill.
Last ditch suggestion... Is it possible that you just need to choose a local drive location rather than your workspace and then the new file types show up?
The built in movie exporter in Creo hasn't been updated since they folded it in decades ago. It is out dated and terrible.
I would suggest looking into screentoGIF. Its open source very easy to use and will get you a lot better result than what Simulate outputs.
https://www.screentogif.com/
i use
Firstly you need to run the animation, and then go to File --> Save As --> Save a Backup and then select the file type to Movie, Thats it!!! Please refer to
(view in My Videos)
the video attached
Your video doesn't work
Please check now, I have uploaded again!
Videos won't play until a moderator approves them.  Not sure how long that takes...
maybe
