Isolate selected components in assembly
Highlighted
Re: Isolate selected components in assembly
The solution!
Go to 6:25.
This Creo Parametric tutorial shows you how to use Layers in assemblies. The most common use for Layers is to manage the visibility of entities and reduce sc...
Highlighted
Very good... Thank you!
It's more steps than other CAD software... but I'll give this a try.
Thanks again!!!
Highlighted
Hi @creuz and @doneill
Creo command search can translate solidworks commands to Creo.  So just type in "Isolate" and the Creo command is shown.  Layers and simplified reps are useful but not as simple as "show-only" which is a "one-click" just like many other software.
Show OnlyShow Only
I think everyone overlooked this simple answer because these show/hide "eyeball" icons are universal to many software.  Just in case... another basic function is to activate the part you want to work on.
ActivateActivate
ActivatedActivated
Highlighted
Oh cool! The command is not working for me though. Clicking on the search result doesn't do anything, and after adding it to my shortcut menu, it is greyed out. What am I missing?
Highlighted
What version of Creo do you use?
Also, possibly you need creo helpcenter installed.  Clicking the search should open a text box to the left.
Make sure you are in an assembly and picking parts from the model tree.  The show-only should pop up for both left and right clicks.
Highlighted
4.0
Highlighted
Aha, I think it might be newer than Creo 4.
Highlighted
Also see this thread
Highlighted
Here is a good work around I came up with.
Creo 4 does not seem to have a "hide all parts"  so instead use a "hideall" mapkey that will make it pretty quick to do isolate.  I used the F8 key for the mapkey.  So the process is hit F8, then select the parts to unhide, then select unhide.
It works by searching for all *.prt in the model tree (binoculars), adding to the current selection (+) then hide, then delete/clear the *.prt from the model tree search. (you can record this yourself or use the "code" below.)
Unfortunately Creo does not remember what was selected before hitting the mapkey (F8) so it has to be 2 steps instead of 1.
You could just add this to your config.pro file.
mapkey $F8 @MAPKEY_LABELhideall;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.simple_search_ph.ss_key_input_panel` \
mapkey(continued) `*.PRT`;~ Command `ProCmdSimpleSearch` ;~ Command `ProCmdSSApplyResult` ;\
mapkey(continued) ~ Command `ProCmdViewHide` ;~ Command `ProCmdSSClear`;
Highlighted
Thank you...
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
