ModelCHECK capabilities?
Re: ModelCHECK capabilities?
@ptc-4779205
- No option for Blank components.
-  For drawing Format, error/Warning will list all sheet formats, select required one and select appropriate format to apply. It will not apply to all sheets.
Hi Mahesh,
One more question regarding the drawing format relations. In the drawing some one is deleted the format relations. Does modelcheck investigate those broken relations?
EX:
&PTC_WM_REVISION
&PTC_WM_VERISION
&PART_NUM
&DWG_NUM
Thanks again,
Naidu
I don't know if ModelCHECK can detect a missing parameter on the drawing format.   I am not performing this kind of check, however it is interesting especially for &PTC_WM_REVISION
Ya, This question comes up from Manager and he is asking me to check this.
@ptc-4779205
There are not much options for drawing format.
Relations for drawings are not available in ModelCHECK
That's correct.  I heard CREO 5 the modelcheck will be enhanced dramatically but I am not sure if this is true or not.  The functionalities have not changed in a very long time.
Okay..Thanks for all your responses. Appreciate your help.
I have some basic question, when I run the model check for drawing I am getting message like below snap, Can you help me to understand about this? does it check for all the drawing models? I didn't find any difference if  click Y or N
Here you are trying to run MC on a drawing.
If you accept the value of "N" then only drawing is checked. if you type "Y" and accept then first model is checked and then the drawing is checked.
Then if you use "Y" and run MC then on the report you will see "drw models". when you click on this you will see a list of models and upon clicking on the model name, you will able to see the MC report for that model.
Hope this clears.
@ptc-4779205
I think information shared by @manjunathrv will answer your query.
It would be great if you can post new queries as new post under System and Administration group.
