ModelCHECK capabilities?
Re: ModelCHECK capabilities?
When you run ModelCHECK (Interactive Mode) on the drawing, it'll prompt you if you want to run the check on your model.  If you select "yes" it'll run the model in a batch mode and store the result in your ModelCHECK folder.  Check your output folder and you'll see the result there if you select "yes"
