Multi Point Constraint
fstopelli-2
Hi!
Do you know if is possibile to manipulate the MPC or not?
Thank you
sorry?
May you better argue your question?
Maybe this is what you are looking for???
Since it is not allowed to constrain the dependent node on a weighted link, use a rigid spring to transfer the "manipulation".  Then the SPC on the other end of the spring can be manipulated by a function.
There is a restriction on the magnitude of rotations with Creo "mulitpoint constraint" in large deformation analysis.  Animations usually my best way to detect when things start acting wrong/strange.
This spring-link method is a common method.  You will find many similar and probably better examples from @skunks if you search.   Posting a specific example similar or simplified from what you want to accomplish would help us help you.
MPC manipulation?MPC manipulation?
restrictionrestriction
