Piece weight permanently displayed.
DenisJaunin
hello,
In this simulation, we see the weight of the piece permanently displayed at each change operation room.
How come this operation.
Kind regards.
Denis.
http://www.youtube.com/watch?v=PzwHB6R1iho
It is a 3D note or annotation with the weight parameter to show the value.
Hello, David,
Thank you for your reply.
But there whenever the previous weight that fits, so we can not have the same setting for two different variables.
Kind regards.
Denis.
Maybe they typed that in.
I agree with David:
The current mass is shown by the system mass parameter and the original mass probably has been just added as a fix text or it exists as a parameter in the model that does not change during modification of the model.
For example you can use a relation old_mass = pro_mp_mass to assign the valuevalue, then comment the line for later use (if you want to make another mass the current one, just uncommment and verify relations).
Gunter
