Problem in specifying rotation constrainsts
SOLVED
Re: Problem in specifying rotation constrainsts
Hey SweetPeasHub,
This explanation isn't helping perfectly. as I have tried doing it but still landing on some errors with contact and constraints.
Is there any way to convert your files and open in Creo 4.0
I don't know of a way to convert from Creo 5 to Creo 4.  Also there are just so many steps taken to describe.  I can give images... sorry too many words to explain.  I will let you ask the questions where it is unclear.Bolt_preload.PNGGear_Load.PNGConstraints.PNGLoad_Function_Dialog_for_preloads.PNGPreload_Function_timing.PNGAnalysis_Def2.PNGAnalysis_Def.PNGroll_pin_defeature_and_CutMatch_to_hole.PNGbolt_defeature.PNGGear_teeth_Defeature and 3 surface region curves.PNGTheta_Constraint_on_pin.PNGLoads_Consts2.PNGLoads_Consts_1.PNGall_helper_Springs.PNGpreload_hand_pin_helper_Springs.PNGConnectivity.PNG
