Reaction moment at the constraint
OptimistishHerr
Hello all,
I am currently calculation a body in which i am applying a moment to a gear and the shaft of that gear is fixed in rotational direction.
How can i measure or detect the reaction at the shaft in terms of moment.
I have used cylindrical co-ordinate system to constrain the rotation and just defining a measure does not work if the constraint is applied other than WCS.
Please put some light to solve this problem.
Thank you
att.
