Regenerate question
SOLVED
Newbie
Regenerate question
When I regenerate my assembly, I get a warning at the bottom of the screen stating;
"Cannot update placement of component(M198)"
Does anyone know how to find out what component is "M198". I don't have a part named M198, so I assume it's some kind of designator.
Any help would be appreciated.
August
Re: Regenerate question
Hi, try another 2 options in the search tool as in the picture above :
1. Go to "History" tab, look by ID = 198
2. If not found, in same History tab look by Feat Number = 198
If still not there (and given you have Yellow regen sign) - try to look by Status = Frozen.
Best,
- Vlad
19 REPLIES 19
Could you attach the assembly and the parts?
The assembly is huge. I can't attach it or the part, because I'm not sure what part is M198.
I thought it might symbolize a part in my assembly, but no parts have that name.
Inside the folder assembly, have you change manually the name of the part?
No, I've searched for M198 and there is no part named that in my assembly.
Has M198 in a different folder?
Are you using folders to simplify your assembly?
Have you tried using the "search tool". Set the "look for" feild to "component" and enter your value of "M198"SEARCH+TOOL.png
Send an image of the assembly components (the tree on your left side).
James,
I tried that and it can't find the component.
Any other suggestions? I'm getting a yellow circle at the bottom in regeneration manager.
Can you post a screen shot of the message log, with the error?
