Regenerate question
SOLVED
Re: Regenerate question
I had to do a quick print screen becausM198.jpge it only flashes for a couple of seconds when I regenerate. Look at the bottom of the screen.
Hi, try another 2 options in the search tool as in the picture above :
1. Go to "History" tab, look by ID = 198
2. If not found, in same History tab look by Feat Number = 198
If still not there (and given you have Yellow regen sign) - try to look by Status = Frozen.
Best,
- Vlad
Vlad,
That did it. I did the search for the id 198 and it identified a screw. The screw was not fully constrained. Once I constrained it, I found a couple of more like that. This was a conversion from Wildfire, so maybe that's why they weren't fully constrained anymore.
Anyway, I really appreciate the help!
August
Usually what I do in cases like this is open the trail file and search for "cannot update placement" Usually it gives you more information about what component is failing.
For example, the assembly I am working on right now shows this in the trail file:
!%CWComponent id 495 of model 20015508_DOORS_OPEN is family table driven and will use pre-Wildfire3 replace functionality
!%CEFailed to replace member 168111 (M495), 20015508_DOORS_OPEN.
!%CWWARNING: Cannot update placement of component (M495).
!%CWComponent id 497 of model 20015508_DOORS_OPEN is family table driven and will use pre-Wildfire3 replace functionality
!%CEFailed to replace member 168111 (M497), 20015508_DOORS_OPEN.
!%CWWARNING: Cannot update placement of component (M497).
It tells me what model is failing. In this case, another engineering groups part (not mine, my stuff is perfect...LOL), apparently did a family table to open a door and something about it is failing.
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
Stephen,
I tried that and I found them, but all it says is "cannot update placement of component (M19X)". It doesn't state where in the model or subassemblies that component is found.
Funny, mine looked exactly like that but just past that part, it gave me the additional information.
Stephen Williams
Very welcome, August. "M" in prefix refers to a "member" - while number is an ID.
Btw, regarding your note "it only flashes for a couple of seconds when I regenerate." - you can always get to the full regeneration log by placing a mouse over the message area and RMB > Regeneration Log - it will open the window with full list of messages. Or like mentioned by Stefen read the trail file - it contains pretty much similar info (just more complicated to get to it among all other rows).
If you have assemblies that showed as fuly constrained in Wildfire and now report as having problems - please submit them to TS, this should not happen.
- Vlad
Using "Solid Model" to find "M198"
I do not know if this is the right place to pose my question. I do not know how to post my question in the forum.
I tried to numerically solve a nonlinear boundarly layer equation in Mathcad 11 and Mathcad 15. I get slightly different results with Mahcad 11 apparently giving more plausible results. Any idea why?
