Spring in mechanism doesn't move back the body
Newbie
Hello all,
I tryed just yesterday some feature of the mechanism module in WF4.0.
I found amazing springs, but they are not working as expected.
I'moving a body using a cam with liftoff option, so when this body loose contact to the cam I was thinking that using the spring it goes back to the starting position.
It's not working like that, body stuck in the top position without going back.
Anyone can help?
Thanks!
Re: Spring in mechanism doesn't move back the body
Hi
Check for
1.Spring properties
2.Enable Gravity
K.Mahanta
Springs are part of Mechanism Dynamics. Please check whether you have the licence for it. Else you cannot enable gravity.
