Thermal Analisys
fstopelli-2
Thermal Analisys
Hi!
In Simulate, Is it possibile investigate time to cool a piece from T1 to T0, T1>>T0?
I have not experience with Thermal analysis
Thank you
14 REPLIES 14
120° cooling down 4 Sek
fstopelli-2
(To:skunks)
what does it mean "4 sek"?
Where I can see the time to cool down from 120° to 25°?
Thank you
fstopelli-2
(To:skunks)
To obtain this graph:
"Analysis and design studies" -> "Temp_1min" -> "Result Window Definition" -> "Display type" ->
"Fringe", "Graph" or "Vector"?
Sorry, I don't know the command to show the graphMan Frustrated
fstopelli-2
(To:skunks)
Hi Shunks,
 in "structural mode"  why you define a MECT Load and a Static Analysis?
Thank you
just like that, to show Smiley Happy
fstopelli-2
(To:skunks)
Hi shunks,
i don't understand this graph trend, is there an error?
Thank you
in the beginning, the temperature graph is unstable, is normal in thermal
fstopelli-2
(To:skunks)
Hi Shunks,
In your example You define 2 different boundary conditions on the same surface..
if I try to it, It appears the attached message.
Maybe I Wrong
fstopelli-2
(To:fstopelli-2)
I tried to do analysis but there are problems...
loadset1->boundary condition1
loadset2->boundary condition2
fstopelli-2
(To:skunks)
Sorry, it's not clear....
