Thermal Analisys
SOLVED
Aquamarine
Thermal Analisys
Hi!
In Simulate, Is it possibile investigate time to cool a piece from T1 to T0, T1>>T0?
I have not experience with Thermal analysis
Thank you
Tags (3)
14 REPLIES 14
Re: Thermal Analisys
120° cooling down 4 Sek
what does it mean "4 sek"?
Where I can see the time to cool down from 120° to 25°?
Thank you
To obtain this graph:
"Analysis and design studies" -> "Temp_1min" -> "Result Window Definition" -> "Display type" ->
"Fringe", "Graph" or "Vector"?
Sorry, I don't know the command to show the graphMan Frustrated
Hi Shunks,
In your example You define 2 different boundary conditions on the same surface..
if I try to it, It appears the attached message.
Maybe I Wrong
I tried to do analysis but there are problems...
loadset1->boundary condition1
loadset2->boundary condition2
Sorry, it's not clear....
