Okay everyone, I have tried and tried to find this config option online and all around creo.
The config option that I'm referring to is something along the lines of right click options having underlined letters on some of the options; this may or may not exist in Creo 3.0, but it does exist in Creo 2.0.
for example you could select two dimensions in a drawing and rmc then just tap "g" on your keyboard, then Creo would "align dimensions".
also "properties" was another that I used often.
I'm not sure if this function was lost in Creo 3.0 or if I just cant find it.
