Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
WF 3.0 M200 PDMLink 8.0 M030 We are testing Dell M6400 laptop with Qudro FX 3700M. It has a wide screen display, but in full screen mode Pro/E models are getting stretched instead of scaled. Is there any fix that will let user be in full screen mode without distorting models? Thanks! Regards, Yugendra Yugendra Bhide Design Engineer Norse Dairy Systems Phone: (614) 421 5305 Fax : (614) 421 5438 www.Norse.com <blocked::<a style="COLOR:" blue;=" text-decoration:=" underline"=" target="_BLANK" href="http://www.norse.com/">">http://www.norse.com/> This email and any files transmitted with it are confidential and intended solely for the person(s) or entity to whom they are addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this email in error, please contact the sender and delete the material from any computer.
