Trying to hook up a 3D Gauges to show simulation of extreme temperatures. Like to have two static gauges with extremes of high and low, and one that show that product staying within a functional range no matter environment? Believe this is able to be achieved inside the Vuforia Studio w/o other programs. Is this the case?
Is you aim to have a gauge that indicates if the temperature is too high or too low? You could do this with just a single gauge that shows the current temperature value and use state based formatting to change the colour based on the temperature value.
Have a look at this post for an explanation of how it works: change the color gauge 3D twx studio
Hope this helps,
Allan
