I'm changing the 'src' value for 3D Images in my experience and experiencing an issue. Here is the situation:
In Studio the 3D Images do not have Height of Width set, just a scale value. While the experience is running I use JS to change the src of the images via $scope.setWidgetProp()
The initial images set in Studio have correct proportions but then when I change the source (the new image does not have the same HxW dimensions as the original) the new image is forced into the save HxW "box" as the original and is distorted. Is there a way to force the 3D Image widget to update the "auto" proportions after you change source?
