Animation of CAD model
SOLVED
Level 6
To animate the CAD model, e.g. for following instruction, is CREO Illustrator the only method?
1 ACCEPTED SOLUTION
Re: Animation of CAD model
You can also use model-items and javascript to animate your model.
9 REPLIES 9
You can refer to following steps to create animation @ ThingWorx Stuio,
Step 1. Create Animation in Creo DAO、MDX or MDO
Step 2. export animation result to *.fra
Step 3. export Creo Assembly to *.pvz
Step 4. Open "1st" Creo Illustrate then import *.pvz
Step 5. Import animation file(*.fra from Creo DAO、MDX or MDO) in "1st" Creo Illustrate "Animation"
Step 6. Open "2nd" Creo Illustrate then import *.pvz --> Click sequence
Step 7. Copy keyframe of "1st" Creo Illustrate then paste to sequence of "2nd" Creo Illustrate
Step 8. Preview animation result in "2nd" Creo Illustrate then publish to *.pvz
Step 9. Using *.pvz with animation @ TWX Studio
sono arrivato fino al punto 6 poi non capisco come fai ad aprire due illustrate.
Me lo puoi spiegare meglio?
Grazie mille.
Hi Matteo,
Creo Illustrate can't create animation and kinematic mechanism  easily. We can use workaround to this instead of Creo Illustrate animation. You can refer to the link below for more detailed information.
https://community.ptc.com/t5/Studio/Is-possible-to-Play-an-Animation-not-a-Sequence-in-TWS-from-Creo...
Hi JingMaoCheng,
this was clear to me.
I arrived up to point 6 of the explanation.
I imported the animation into Illustrate and it works correctly.
Now I want to turn it into a sequence but I do not understand how it's done.
I can open one Illustrate at a time and not two as described in point 6 so I wanted explanations about it.
Thanks Matteo.
Hi Matteo,
We have to create 2 different types
of figure -> animation and sequence in 2 different Creo Illustrate
sessions and to copy an animation to a sequence step. Attached you will find the recording video for your reference.
(view in My Videos)
How would you go about animating a model in javascript?
Have a look at the Studio Sample Quadcopter that you should have in your Projects list.  It's got a bunch of movement examples that are a great resource.
Also have a look at the example in the Tutorials in the Help files: Translate Models and Model Items Using JavaScript
Hope this helps,
Allan
Hi JingMao Cheng,
I managed to create the sequence passing from the animation. (PROCEDURE: once you have loaded the .fra file done with the mechanism and created the animation, I copy the frame and move to the sequence without using 2 licenses).
In illustrate version 4.2, everything works correctly (see file illustration2.c3of)
When I load the pvz in Vuforia studio and I go to use this sequence it does NOT work. The preview even stops. (See experience: PROVA_RONDO.zip)
A questo link trovi i files: https://we.tl/t-Oq2ITieWhD
