Hii,
If I create a Mobile 2D project I get a large amount of available widgets (29 widgets including Text Input). If I create a 2D Eyewear project I get only 12 widgets.
The eyewear I use has a microphone, so normaly I can use Text Inputs via voice, but I don't have the widget for this.
@drichter We understand at the moment not all widget are available in both 2D project type. I can check feasibility for such a widget or see if there is already a plan to implement & have similar widget.
-Durgesh
