I am trying to overlay data from Thingworx on a pump model at different locations, I need to overlay pump data on pump, pipe flow data on pipe. I have a 3D model of the setup, can I just use the model for detection and proper placement of data in 3D plane without displaying. I guess the Blue Pump tutorial is a good starting point but I can't find the .zip file needed.
So here the Blue Pump Model to download and also the tutorial for the Vuforia BluePumpQuickStart
