Cannot publish my project.
Re: Cannot publish my project.
Hi, Ankit
Thanks for your reply.
Will it empty all of the data of this account? Because there is some others' data, so I should ask them first.
So, could I give you reply on next Monday? And I will try to publish on next Monday again, if there still are problems, I will tell you, too.
Thanks.
Thanks Xi Xie for confirming on this. Can I also request a screenshots of Studio 'Settings' dialogue box and 'Portal Login' dialogue box?
-Giri
Hi, giri
Thanks for your follow up.
Here you are.
And I always configure manually, so it keeps empty.
Wish these can help you.
By the way, are there any instructions documents for our reference about the log errors and how to resolve them ?
Thanks.
Hi xi xie​, Yes, it will empty all data of ThingWorx instance.
I will reach out to R&D for reset only after your confirmation.
Do let me know when you are ready for the reset.
hi, Ankit
I'm sorry that this account has a lot of others' data, so I cannot empty it.
I have tried some other ways to publish, though it sometimes fails, too.
Maybe it's due to the network speed.
For the moment, keep it in the situation.
Thanks very much.
Hi xi,
I have sent you an email to know your availability for a WebEx meeting. Could you please check same.
Ankit Gupta
Hi, Ankit
I have received your email.
I will let another colleague, Minna, to contact you.
She will schedule a WebEx meeting ASAP,and then we will show our issue to you.
Thanks.
Hi xi xie​,
Thank you for the update. I have received the invite from Minna and we will discuss this issue on WebEx.
Ankit Gupta
Hi xi xie​, I received an update from R&d on this issue:
After further investigation, it appears that the issues you are seeing have to do with poor network performance -- either low bandwidth, high-latency, or lossy conditions.
We hope to improve performance and stability in poor network conditions in future releases.
Could you please confirm the version in which publish was working. I will check with R&D if it is possible to rollback to previous version and check what has changed in the version which could cause this issue.
Also, could you please recheck if any change in your Network/Firewall settings were made recently?
