Change Video speed
mn1
Level 8
Change Video speed
Hi there,
is there a possibility to set the speed of a video manuell? I would like to play the video with a lower speed.
Thanks for help!
Re: Change Video speed
@mn1  I believe you are using Video widget and as such we do not have direct way of changing video playback speed.
I am checking if there is a workaround or way to do that or not . Is there any specific value you would like the playback speed to be ?
-Durgesh
Yes, I'am using the video widget. You are asking for a specific value of the speed. Maybe you can try it with 50% of the original speed.
