We have the strong need to document the steps during an experience. We want to save the displayed information (AR model + real background) and send this content to THINGWORX for follow up documentation purposes.
Is there a way to get to the real time feed, camera object or anything else to obtain a still of the currently displayed image?
So far I found the JavaScript Object "Camera" in the sourcecode offering the method getPictureData as well as getPictureURL; however I do not get the image data when I execute this method on the mobile device.
@gbirnzain I m not sure if we have a direct feature to capture details of your use case however checking internally if there are workarounds to achieve this at the moment in Studio.
-Durgesh
Hi! Any info about screenshot in Vuforia Studio?
I am intrested in the screenshot option in Hololens. Then I would like to use this screenshot for other features like PDF generation.
What you think? Is it possible?
Regards!
Adam
@A_Macierzynski - We do not have this feature available in Studio however not sure of any workaround available.
Is your use case is like capturing details or procedure ? Not sure about exact use case however would like to share that we have added a new product Vuforia Capture which you could check out/explore.
-Durgesh
