Data URL instead of a XMLHTTPRequest, how?
SOLVED
Re: Data URL instead of a XMLHTTPRequest, how?
No, I don't think you'll be able to store a new JSON file from a script. If your goal is to persist some data across sessions, you will probably have better luck using the Thingworx connection to store data there. You could also try using localStorage, but I have no idea if that would work on devices running Vuforia View.
