Does ThingWorx Studio support stand-alone viewing?
Level 1
        Currently through ThingWorx Studio release project to the server and through ThingWorx View view the effect is very slow, often show no effect, is there a stand-alone version of the function, you can directly preview the effect locally, such as: generate exe program running on the local compute.
Re: Does ThingWorx Studio support stand-alone viewing?
For direct preview, did you try Studio preview feature? Let us know if the preview isn't suitable for your use-case, if possible do share a brief description of your usecase. And a local exe program isn't available with ThingWorx Studio.
Hi,giri:
       The browsing function has been tried, but the actual size and effect are different from those shown by the view. Whether it can build a server in the local, slow and slow to solve the slow release and slow browsing problem?
By saying build a server in the local, do you mean setting up a local ThingWorx Experience Service and ThingWorx Studio?
