Error while accessing a project.
Re: Error while accessing a project.
Hi Yoo hwan​,
Thank you for the details. I will check these details on my Server.
In general; Adminstrator user in ThingWorx have access to all entities in ThingWorx. But to make sure that Administrator user has access to your entities; you can open the entities and provide visibility and runtime permission to the Administrator user explicitly.
It also makes sense to provide these permission to the 'es-public-access' user. I suppose this user does not have access to your entities.
I will test/analyze this more and will get back to you with an update soon.
Ankit Gupta
Hi Yoo hwan​,
Thank you for the details. I have provided this URL to R&D for a restart.
Do let me know if you require any help in setting up the Permissions.
Hi Yoo hwan​, Did you get a chance to check the permission for the entities? Does 'es-public-access' user have visibility and runtime permission for the entities you have created in ThingWorx?
Hi Gupta
'es-public-access' user has a permission for the Thing deservedly.
'es-public-access' user is included in the Development Organization.
I checked Thingworx studio logs.
[10:31:32] info: [twx-studio:basic] twxPreviewRouter proxying request to "https://shsivrbg.pp.vuforia.io"
[10:31:32] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Services/CPUchartDraw no Authorization added
[10:31:32] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Services/HourlyPieChartDraw no Authorization added
[10:31:32] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Services/query no Authorization added
[10:31:33] info: [twx-studio:basic] twxPreviewRouter proxying request to "https://shsivrbg.pp.vuforia.io"
[10:31:33] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/RAM_Total no Authorization added
[10:31:33] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/PC_Name no Authorization added
[10:31:33] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/UserName no Authorization added
[10:31:33] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/IP no Authorization added
[10:31:34] info: [twx-studio:basic] twxPreviewRouter proxying request to "https://shsivrbg.pp.vuforia.io"
[10:31:34] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/HardDiskPct1 no Authorization added
[10:31:34] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/RAM_Usage no Authorization added
[10:31:34] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/HardDiskPct2 no Authorization added
[10:31:34] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/visible no Authorization added
[10:31:35] info: [twx-studio:basic] twxPreviewRouter proxying request to "https://shsivrbg.pp.vuforia.io"
[10:31:35] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/ModelVisible no Authorization added
[10:31:35] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/ProgramNum no Authorization added
[10:31:35] debug: [twx-studioSmiley Tongueroxy] /Things/HaeriThing/Properties/CPU no Authorization added
[10:31:35] debug: [twx-studioSmiley Tongueroxy] /Resources/EntityServices/Services/GetClientApplicationKey no Authorization added
[10:32:46] debug: [twx-studio:sockets] user disconnected
However I authorized the 'es-public-access' user to get client application key.
I referenced this link.(https://help.vuforia.io/studio/#page/ThingWorx_Studio_Help_Center%2FGrantUserPermissions.html%23wwID...
Now, Errors as below are accumulated continuously in Thingworx composer.
Also preview in Thingworx studio does not function properly either.
Thanks.
