Facing problem while using multiple sequences using list and select option
SOLVED
Re: Facing problem while using multiple sequences using list and select option
Please share the log file.
I will compare it with mine to find a difference.
After that, I would recommand to reinstall Vuforia View.
Best regards,
Samuel
Please find below screen shot of my device in which i am getting tracking loss error earlier i am not getting such kind of errors.
Thanks for the solution for initial vale of sequence list view.
Thank you
  • Do you still have tracking issue in your last test ?
  • Does a new version of Experience has been published in Experience Service ?
  • Does have the same environment (lights, plane surface ...etc... as the previous tests)
Best regards,
Samuel
