How can we increase brightness of model in studio for hololens project.
SOLVED
Level 8
I imported .PVZ file from Creo Illustrate but i am not getting same color like Illustrate in Vuforia Studio.
It decreases brightness of model. How can i increase model brightness in VS.
OR
Is there any other way to import same color model in VS.
Swapnil More
Re: How can we increase brightness of model in studio for hololens project.
If the right color is not showing its most likely because you have not specified a sequence. You need to choose the figure in which you have applied the colors to.
Also make sure "Apply sequence at design time" is marked
