I imported .PVZ file from Creo Illustrate but i am not getting same color like Illustrate in Vuforia Studio.
It decreases brightness of model. How can i increase model brightness in VS.
OR
Is there any other way to import same color model in VS.
If the right color is not showing its most likely because you have not specified a sequence. You need to choose the figure in which you have applied the colors to.
Also make sure "Apply sequence at design time" is marked
