How do I make the 3d label look at the camera?
SOLVED
Level 12
Hello
The 3d label is static.
Is there a way to set the 3d label to see the camera even if the camera rotates?
Please let me know.
thank
Re: How do I make the 3d label look at the camera?
Select the tick box for "Billboarding" for that particular 3D label widget. Then the label will always face your point of view
