All software and hardware up and running.
When i upload a model, how do i get around my model??
It is far away, and as I walk it stays far away. Seems to stay the same distance from the hololens ....
Same model tested on Ipad, no problem there.
Koen
Problem solved, playing with Marker Width (now 0.1) & Model Scale solves the problem.
Yes the Marker Width in Thingworx Studio should be the same size as the actual Thingmark, units are in meters
